I Can't seem to get my seat FULLY off, there is some clamps in the middle of the seat that r holding it on???
Old Mar 29, 2004 | 10:54 PM
numbr1azzkikr's Avatar
Default I Can't seem to get my seat FULLY off, there is some clamps in the middle of the seat that r holding it on???
Can Anyone help me with this???
Old Mar 29, 2004 | 11:17 PM
HappywithVForce's Avatar
What kind of bike??
Old Mar 29, 2004 | 11:21 PM
LuvDaMud's Avatar
It would kinda help if we knew what kind of bike you have?????
_________________________
2003 P650 Red
Holeshot Module
Dalton Clutch Springs
ITP Cast Alum Rims
26in Bear Claws
Full Equiped
Old Mar 29, 2004 | 11:49 PM
vtwiner's Avatar
If it's a V force, Push down on the back of the seat while pushing down on the release lever. This takes the pressure off the bar clamps and should work for you. Good luck!
Old Mar 30, 2004 | 08:23 AM
Srry its a MOHAVE and i dunno y and the hell kawasaki makes it so freakin hard ot get the seat off? so could anyone tell me??
Old Mar 30, 2004 | 09:41 AM
kawakasi's Avatar
Look underneath
there are two bolts that go thru the grab bar....and thru the frame
pop them out and you can take the whole back plastic off
then its alot easier to get to the seat bolts
really not much reason to take the seat off.....you must be replacing it???????
Old Mar 30, 2004 | 12:32 PM
4wheelsRbetterthan2's Avatar
KawaKasi is right. After removing those bolts, the seat is bolted to the rear plastic and that would only be held on to the bike by the plastic tags that go into the frame under the base of the gas tank. If you have the mud flaps on the rear also, you will either have to disconnect them from the rear plastic, or from the heel guard (I zip tied mine so it's a simple cut and replace).
good luck
Old Mar 30, 2004 | 05:46 PM
I needed to know how to get the seat off cus i was wondering if i would have to take it off to install a pro design kill switch? If so, does anyone know where the ignition box is located and wut wires and stuff to clamp the kill switch wires to. (pretty much jus explain to me how to install a pro design kill switch) Thanks!
Old Mar 31, 2004 | 02:45 PM
mojaveaddict's Avatar
i answered in your other post
bmxatv10
Oct 14, 2022 06:23 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
