my axle nuts keep spinning loose
Old Mar 30, 2004 | 02:37 AM
bansheeorbust's Avatar
Default my axle nuts keep spinning loose
i tried loctite and did nothing, PERMANENT LOCTITE not the blue stuff, what now???
Old Mar 30, 2004 | 02:42 AM
DuneMe's Avatar
Does the outer nut have holes for allens to lock it in place like the Raptor? Those allens can fall out and the holes can be overlooked.
Old Mar 30, 2004 | 03:06 AM
no it does not have that
INSeaRChOFDUNez's Avatar
Just get an aftermarket double pinch locknut (what i got). it did wonders for my axle no more retightning it every stop. JMO
Old Mar 30, 2004 | 10:26 AM
RaptorOwner's Avatar
Same here solved my problem the first time.
Old Mar 30, 2004 | 11:37 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Also: it is important to be sure to seat the bearings properly when installing. If they are not all the way in,,,,it will seem as if the nuts have loosened,,,,when really the bearings just settled into place.
mark the location of your nut (on the axle) with a small drop of paint,,,touching the axle and the nut (after you tighten it), to see what is actually moving (the paint drops will misallign).
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
