simple problem on the vforce
Old Mar 30, 2004 | 06:48 PM
coyote81's Avatar
Default simple problem on the vforce
In a race over the weekend my vforce kept dying and finally it lost all power at once. I blew the fuse under the seat that is coved by a red cover. Problem was the wires coming out of my CDI box had be rubbing against my frame and decided to ware through during the race. Just a little black tape should take care of the problem. Just wanted to make everybody with a vforce aware.
Old Mar 30, 2004 | 07:24 PM
Kawy's Avatar
Wher exactly did the wires rub through? In other words is the CDI the little black box on the stock exhaust side up under the rear fender? This just happened to me as well and I can't figure out why!!
Old Mar 30, 2004 | 07:35 PM
coyote81's Avatar
looking at your atv from the rear it will be under you right fender. You will see a black box with two different wiring harnesses coming out. The wires come out and run over the frame.
Old Mar 30, 2004 | 07:46 PM
Kawy's Avatar
So was it real close to the CDI that the wires rub the coating off and shorted out? I wonder if we should run electrical tape aoalong the wire!
Old Mar 30, 2004 | 08:16 PM
MnFriesen's Avatar
The wiring that kawi did for the V seems a litle under par...do you think it will be wired a little different on the 05's?
Old Mar 31, 2004 | 02:56 PM
coyote81's Avatar
I agree that the wiring is under par. Im going to run some black tape around the wires that have been damaged and check other vulnerable place that shorts could occur. About what fixes that are going to happen for the 05 I dont know. The wiring problem and the tie rods are the only thing that I really got complaints about. So far Ive been please with the vforce. Ive only had mine for 8 months so Im sure there will be other ploblems, I just hope they're not to costly.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Schneider
Jul 24, 2015 05:05 PM
hondarider1234
Jul 21, 2015 11:53 PM
