STOCK SHIM THAT COMES WITH V FORCE
I was wondering if anyone is running a different primary spring with no shims at all? The V Force comes with a shim under the stock primary spring. Can you run a HPD plain spring without the shim or will no shims hurt the clutch where the spring comes in contact with it? Thanks......
