no results
Old Mar 31, 2004 | 09:42 PM
Pushinlimitz's Avatar
Default no results
ok im shure ive got a timing problem , when i start it ,it idles and misses , if i give it gas ,,,all it does is back fire, but it doesnt rev up at all, it just idles and misses . i even tried spraying eather in the carb while it was runing and it did nothing , i also sprayed it all arond the carb , it just idles and missed. my mechanic friend thinks it may be a reed thats not seating or may be cracked, he thinks its a air problem because when i floor it doesnt rev up but it back fires, so its geting lots of gass but not the right amount of air . what do you think? also does anyone know if there is a timing mark on the flywheel??
Old Mar 31, 2004 | 10:27 PM
CED's Avatar
CED
Default no results
You will need to pull the flywheel off to check the timing there is a mark on the stator and a mark on the case.Also check the keyway on the crankshaft where the flywheel goes .This could be some of your problem.Ive seen the key shear and give the same results that you described.Was the flywheel ever replaced ?
Old Mar 31, 2004 | 11:33 PM
Default no results
im not shure if its been replaced , i bought this quad and it did this 2 days latter . i took off the cover and the nut and tried to pull the fly off but its VERY tight and it dont look like its spun ,i can see the key it looks ok . it just doesent look like its moved even a little. could my friend be on to something with the reed, how hard are they to get out???
Old Apr 1, 2004 | 09:05 AM
CED's Avatar
CED
Default no results
Pull the carb off ,then the rubber intake and the reeds are right there.Give it a shot.
Old Apr 1, 2004 | 02:19 PM
DexRex's Avatar
Default no results
I would check the spark with a timing light and rev the engine to see if the ignition is firing at higher RPMs. If it cuts out, you might have a stator or coil problem....
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
