02 raptor with clutch problems
Old Mar 31, 2004 | 09:46 PM
sherwood1976's Avatar
Default 02 raptor with clutch problems
i have an 02 raptor and today i noticed a lose in power. i have to gas it more to go and the clutch is all the way open. i can also sit and put it in gear and let out the clutch and it will not die....it will idle. any help will be nice, thanks
Old Mar 31, 2004 | 10:07 PM
wshrdskin's Avatar
Do you have any play in the clutch lever. Meaning when you pull it in is it free and easy for say a 1/4" gap between the lever and the bracket before it gets harder to pull in? If not adjust it until it is. Otherwise, it sounds like your clutch plates need replacing.
Old Mar 31, 2004 | 10:31 PM
how much are clutch plates?
Old Mar 31, 2004 | 10:49 PM
wshrdskin's Avatar
A new GYTR clutch is around $100. It comes with the plates, fibers and new heavy duty springs. Otherwise you need
6 of part #5Y1-16321-00-00 friction plates @ $6.43 each
7 of part #498-16325-00-00 clutch plates @ $13.46 each
2 of part #5Y1-16331-01-00 friction plates @ $15.12 each
You could probably get away with not buying new clutch plates and just lightly sand the faces of each of those and just buy new friction plates (fibers)
I'd just buy a GYTR clutch kit myself.
Oh yeah, you'll possibly need a new clutch cover gasket also.
Part #5LP-15462-00-00 @ $9.16
Old Mar 31, 2004 | 10:59 PM
well i really thank you for your assistance on this. just one more question for you. where can i order this gytr kit from online? i would that is my problem. but i am still confused on what actually happend. i was on a hill and it started smoking real bad so i went to the truck and thats when i noticed the lose of power and being able to sit in gear with the clitch out and no gas and it would just idle. did it just burn up?
Old Mar 31, 2004 | 11:07 PM
wshrdskin's Avatar
RipperRacing a forum sponsor sells them on their website for $93
RipperRacing
Old Mar 31, 2004 | 11:13 PM
wshrdskin's Avatar
It was smoking from the exhaust pipe? If the clutch goes out you will notice the quad reving higher when you give it gas but it doesn't pick up speed as well as it should. With the quad in gear and letting the clutch out and it just sits there, then you have a problem with the clutch in some way.
Were you climbing a hill feathering the clutch etc?
Old Mar 31, 2004 | 11:19 PM
when i was on the hill i had clutch stationary.....in one position. then it started smoking from under the sit.....then lose of power etc! i just messed it up. the clutch is out i bet. does that still deal with the clutch plates? if not how much to fix do ya think?
Old Mar 31, 2004 | 11:24 PM
wshrdskin's Avatar
If you fried your clutch then the GYTR kit will cure it all. Smoke coming out from under the seat doesn't sound good though. Can't imagine that being related to a burnt clutch.
Old Mar 31, 2004 | 11:27 PM
it may have been from the pipe....considering i was on an incline it would go up and that would right under the seat. it does not smoke any more.....just that once. well i checked that site for the clutch kit and it is on back order. any other place to get one online you know of. if i replaced the clutch myself.....how long do you think it can take?
