V-force wheel spacers
on my 02 lakota the bolt pattern 4/156 same as polaris so i figured the highlifter 1in spacers would work on my quad. They did'nt fit in the rims and the bolts were diff. so... my friend turned them down in a lathe and i ran the stock nuts on the stock studs inside the spacer and used the supplied nuts on the spacer studs. i have had no problems and think the highlifters are better spacers then the durablues. you may want to look into the same thing.
I have the 1" High Lifter aluminum spacers on the rear tires of my V-Force. In my photo page there is an inset pic of the rear of my "V" showing the extra width (click on photo for larger view). They fit perfect and the machining on them is awesome.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
