30/70 mix
Old Apr 4, 2004 | 11:49 PM
kfx400guy's Avatar
Default 30/70 mix
is 30% antifreeze 70% water good for summer time?
Prestone is an ok antifreeze, right?
Old Apr 5, 2004 | 09:30 AM
kfx400guy's Avatar
Default 30/70 mix
bump
Old Apr 5, 2004 | 11:50 PM
venforcer's Avatar
Default 30/70 mix
just use 50/50 mix. It will have you fully protected year round.
Old Apr 6, 2004 | 12:23 AM
Chris142's Avatar
Default 30/70 mix
Using less antifreeze will allow better heat transfer. Your engine may run a few degrees cooler. It will also lower your boiling point and cause early wear on the water pump seal.
I don't think 30% antifreeze would be enough to protect the metal parts from corrosion, especially the aluminum stuff.
Their is no difference between atv/ motorcycle antifreeze and car stuff.......Except that the bike stuff costs more. Prestone is fine. So is Zerox, Peak etc. I'd stay away from the Dexcool(aka: deathcool) stuff though.
Old Apr 6, 2004 | 04:13 AM
AlaskaBayouGuy's Avatar
Default 30/70 mix
Used to work at the blending plant that made antifreeze for most of north america, learned alot about the stuff. One post was made that dexcool is crap and im glad that truth has been discovered by somone other than me. Zerex is a good general purpose AF, but you can find it cheaper sold under the Auto Zone brand name, it is literally the exact same stuff just in a different bottle. Peak is OK, although they use a recycled lower grade ethylene glycol as their base. The absolute best stuff out there is a blend called G-05, Sold as Zerex G-05 (yellow) Ford (more yellow) and Mercedes and BMW (blueish green stuff). This stuff is bar-none the best stuff out there and is considerably more expensive, but it has the lowest silicate content of anything on the market which is what aluminum motors need. Run a 50-50 mix, even in Kentucky. I run a 70-30 glycol/water mix in my vehicles but thats kinda needed here in alaska.
Old Apr 6, 2004 | 04:14 AM
Default 30/70 mix
And oh yeah dont run prestone, way too high acid content.
