P-650 module ??
Old Apr 5, 2004 | 02:27 PM
DaveC's Avatar
Default P-650 module ??
I cart wheeled a P-400 doing 35 mph last year, so top speed is not my concern.
Moving my bayboat in and out of the backyard is. When I hook up to it The P-650 pulls it OK on hard top, but as soon as I get into the grass the quad grunts and moans and barely moves it. Exact SAME pulling ability of my 400.
What I'm wondering is if the holeshot module will give me more power below 3mph to move the boat in and out.
Does it also do it's majic in reverse?
If anybody is yanking their Module in favor of the new CDI, I'm interested in it!
Old Apr 5, 2004 | 03:37 PM
Customfabandweld's Avatar
How heavy is that boat?
Old Apr 5, 2004 | 03:59 PM
newbeatle's Avatar
I assume you had it in low range... mine would pull a full size silage wagon full of cut firewood, across a plowed field...I'll bet that wagon weighed over 4,000 lbs, & it pulled it fine, until I got stuck crossing the deep ruts...
Old Apr 5, 2004 | 04:29 PM
DaveC's Avatar
Not too big. Only 18.5' center console w/ a johnson 120.
I'm mostly moving it from the drive way to the side of the house in reverse. It's a slow go process so as to not rut up the grass.
Yes, it was definately in low when going forewards.
Old Apr 5, 2004 | 05:02 PM
newbeatle's Avatar
Have you considered one of the front reciever systems, so that you could use the forward gear ( i.e. Montana Jacks, etc. )... also the new Dyna CDI, eliminates the reverse safety feature, & could help you back up a heavy item, with out using the reverse override button...
Old Apr 5, 2004 | 05:16 PM
DaveC's Avatar
True, but I don't want to have to run premium fuel.
My bike has all the guts I need, except when moving the boat.
Front reciever?, hmm gonna have to look into that.
Old Apr 5, 2004 | 05:19 PM
newbeatle's Avatar
If the rest of your quad is stock, & jetted properly, you more than likely won't need to run premium fuel... there are several manufacturers, that make a front reciever hitch for you quad...
Old Apr 5, 2004 | 05:46 PM
Kawi650's Avatar
the modulator does help reverse. To me there's a bigger difference in reverse than forward. (I use a lot of power in reverse). When I back-up heavy things with the 650 I find that body position is very important so the machine doesn't bog down, I don't know if it's me but try standing in the middle of the floor board instead of sitting on the seat. Now if your backing up over you lawn the modulator will cause your lawn to be torn up faster. I find my old 400 had a lower reverse gear than the 650 (I assume same with the 700). You should try keeping the clutch engage in reverse too, or try a different aftermarket spring.
Old Apr 5, 2004 | 10:03 PM
sledheadrich's Avatar
I say "To hell with the lawn, Let her RIP!" One less spot you'll have to mow. Or maybe the start of a MX track! Hmmmm.......
Old Apr 5, 2004 | 11:43 PM
Timo's Avatar
doesn't that boat cut into your riding time anyways! LOL
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
badprairie
Jul 14, 2003 04:35 PM
epaj50
Jun 27, 2003 02:49 PM
maxemuse
Oct 21, 2002 01:01 AM
