rear shock ques. i dunno
Old Apr 5, 2004 | 05:40 PM
moosin's Avatar
Default rear shock ques. i dunno
my 03 p650 seems to sit a little lower in the rear than my buddys. i was just wondering if the schrader valve on the remote resevior on the rear shock is adjustable (can i fill or deflate it) and can i fill it off a compressor or is it something special inside. if i check it with a tire guagu what psi should it be thankx for any help.
Old Apr 5, 2004 | 05:50 PM
newbeatle's Avatar
MOOSIN... 1st off, that is filled with nitrogen, not air... & while increasing the nitogen pressure does push the shock out to full extension, it is not designed to support weight, like an air shock... the nitrogen helps stabilize the oil, to decrease fade & rebound loss, as the shock heats up... Have you adjusted the springs preload adjustment to full adjustment ??? this is the only proper way to lift the back end with out a lift kit... the nitrogen pressure is typically at 125 - 160 psi... I've heard of people pumping it up to close to 300 psi... however this is not like pumping up an air shock...
Old Apr 5, 2004 | 06:24 PM
deerchooper's Avatar
i noticed the same thing with mine as well. but when i bought it it sat the same height as the other 650's. i have access to nitrogen. as far as the preload i wouldnt want it any harder, it doesnt take the woops that well now. one time i thought i was going to eat dirt, because she was comming over and all i could do is pray.
if the pressure is low that would mean that something is leaking wright?
do they sell rebuild kits for the rear shock?
___________________
02 650p
nyroc muffler
napa #7335
145f/147.5r jets
needles shimmed .033
epi black
700p drive spring
warn 2000
plow
cdi is comming (one of these days)
Old Apr 5, 2004 | 09:46 PM
p700wheelieman's Avatar
all springs [break in] after a while and moto guys actully replace their's you should get your height back just by adjusting the preload colar
Old Apr 6, 2004 | 05:17 PM
moosin's Avatar
thanks guys for the info everything is at its right pressures and dont really need the rear end any harder not that big of a guy. its probably fine its just me over reacting about nothing but thankx for the input may still come in handy.
mywifesquad
8
Sep 21, 2015 08:20 AM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
snowolson
Aug 31, 2015 03:51 PM
