Needle shims on V-Force?
Old Apr 6, 2004 | 12:46 AM
venforcer's Avatar
Default Needle shims on V-Force?
Is anybody shiming the carb needles on the "V" force, and why are they doing it?
Old Apr 6, 2004 | 01:58 AM
Pistonman's Avatar
The purpose is to raise the needle out of the jet to richen the midrange . I believe it will also alter the transition point.
Old Apr 6, 2004 | 02:02 AM
venforcer's Avatar
I am up to 152f-155r jets and is still a tad bit lean. do you think I should shim the needles. The air box is getting lots of air.
Old Apr 6, 2004 | 02:05 AM
Pistonman's Avatar
Where does it feel lean at? Have you read the plugs? Any noticeable stumbles, etc? You can get them at radio shack-.020
Old Apr 6, 2004 | 02:13 AM
venforcer's Avatar
It runs perfect, and will do 72 mph 4000 ft. alt. The plugs are a cream to very light tan.
Old Apr 6, 2004 | 02:20 AM
Pistonman's Avatar
Sounds darn near perfect-with the shims and no other changes it probably will be(perfect)...!
Old Apr 6, 2004 | 02:25 AM
Pistonman's Avatar
Or maybe no changes? Why do you think it's lean? The cream color? I have heard that ideal for general use is where you are at, then a touch richer for safety. Maybe the needle shim would do that.
Old Apr 6, 2004 | 02:27 AM
venforcer's Avatar
Thank you very much for your help, I will do the shims tomorrow and see how it works. Do you think the 72 mph is a good speed for the way I have the mods for now.
Old Apr 6, 2004 | 02:39 AM
Pistonman's Avatar
I think 72 mph is real good! I am still working on my jetting- ordering more tomorrow-- taking out the Dynojet kit! Going to start with .020- 145-148.....Also 2 turns on pilot jet.. It's at 3 with D.J. kit. You are welcome. I have rec. much info here- just passin' it on.
Old Apr 7, 2004 | 01:36 AM
venforcer's Avatar
I put the .020 shims on the needles today and it changed the plug color from cream color to light brown in the mid-range of the throttle. At least now it gives me the option to open up another 1 1/2" hole in the air box that i had closed off. I cut five holes in the air box so i could just tune my air flow by duct taping them off or leaving them open. I fastened 1/4" thick scrubbing pad material to the holes with thin-wall aluminum washers and pop rivits. The scrubbing pad is very pourous and allows air to pass freely. You dont have to oil them,just back-blow the dirt out with air pressure. I will post pics in my bio so you guy's can see how i did it.
