What's the best coolant to use in a V-Force
Old Apr 6, 2004 | 04:24 PM
hazmat1800's Avatar
Default What's the best coolant to use in a V-Force
I was whating to know what the best coolant to use in a V-force. I had a piston problem and when it can back from the shop with the new pistions the fan seems to run more. The bike is stock except for a Twin Air filter. Have not changed jets and plugs are checking ok or a little on the rich side.
Old Apr 6, 2004 | 04:54 PM
n2xlr8n's Avatar
If you a) are stock displacement and b) keep your radiator fins clean, I would run what Kawasaki recommends. AFAIK, it's a 50-50 mix of water and coolant.
Old Apr 6, 2004 | 05:04 PM
venforcer's Avatar
I would say it is due to the engine running a little warmer because the new rings are seating in. When the dealer honed the cylinders for the new pistons and rings, roughness of the cylinders will create a little more heat causing the fan to run more. Everything should go back to normal as soon as the rings get seated in. about 10 hrs. riding time. You will have to go through the break-in period again.lol.
Old Apr 6, 2004 | 05:17 PM
MickeyDunlap's Avatar
Evans coolant. You will no longer need your fan or over flow bottle. It doesn't mix with water so it doesn't exspan like other coolants and it won't boil over unless it gets over 375 degrees, by then everything would have melted anyway[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 6, 2004 | 05:19 PM
hazmat1800's Avatar
It is the stock displacement and I wash the radiator out when i go riding. The fins are not bent and water flows thru with no problem. The coolant that is in the bike is what the dealer put in when he replaced the pistons. I have raode the bike for about 20 hours now and the fans runs even when the temp is in the 40's.
Old Apr 6, 2004 | 05:20 PM
hazmat1800's Avatar
Thanks Micky that is what I was looking for. Any price on your exhaust for the V-Force yet. Thanks
Old Apr 6, 2004 | 06:07 PM
newbeatle's Avatar
HAZ... here is thier web site, for more info, & you can buy it through Mickey...
http://www.evanscooling.com/main31.htm
Old Apr 6, 2004 | 07:50 PM
kfx400guy's Avatar
How much does the Evans coolant cost?
Old Apr 6, 2004 | 08:02 PM
VNASTY's Avatar
Around $25 a gallon from Evans and $9 freight.
Old Apr 6, 2004 | 08:35 PM
Davinator's Avatar
Is this stuff ok to run in the P. I read something somewhere about corrosion. Can’t remember what it was about, or what product. Just don’t want to mess up something I can’t see.
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Supertrapp IDSX exhaust
Primary Dalton Plain\white spring
Secondary EPI black spring
P-700 Belt
28” Mudlites on C's
Warn 4000 winch on front
Warn 2500 winch on back
Headlight mod
