All parts from RCR came today Question #1
Old Apr 8, 2004 | 11:10 PM
BeltDrive's Avatar
Default All parts from RCR came today Question #1
The first thing I'm starting with is the air box mod. I can understand everything but I can't figure out where the new small rubber air intake boot, that came with the kit, should be installed and what size hole needs to be cut out for the boot ?
Thanks
Bob
Old Apr 9, 2004 | 12:59 AM
luvit's Avatar
Call and ask Rick on Friday. He is a great guy and will gladly tell you too.
Old Apr 9, 2004 | 01:04 AM
duneaholic's Avatar
You need to drill a new hole in the middle of the airbox and then install the boot. I think that I used a 1" spade bit to make the hole.
Old Apr 9, 2004 | 01:08 AM
BeltDrive's Avatar
luvit that is what I was going to do but I thought for sure someone here would have an answer. The rubber boot is a extra venturi, I found that out from doing some searching
Old Apr 9, 2004 | 01:11 AM
BeltDrive's Avatar
duneaholic you said in the middle, but where at (top,front,side) ?
Old Apr 9, 2004 | 01:12 AM
duneaholic's Avatar
If you don't do too much mudding or deep water riding you can cut out that restrictive wall out between the filter and front of the airbox. The wall just diverts water that might happen to get into the airbox away from the filter. I cut mine out cause I ride 99 % in the sand. It made a difference.
Old Apr 9, 2004 | 01:14 AM
duneaholic's Avatar
The rubber venturi looks the same as the other two that's already there right.? The two already there are evenly spaced on each end of the front of the box. There's just room enough for another right in the middle in the front.
Old Apr 9, 2004 | 01:15 AM
BeltDrive's Avatar
I was going to cut the wall down but what is the extra venturi for or go ?
Old Apr 9, 2004 | 01:17 AM
BeltDrive's Avatar
Thanks duneaholic you are alot quicker on the keyboard than I am !
Old Apr 9, 2004 | 01:31 AM
BeltDrive's Avatar
I guess I would have known if I would of taken off the inlet boot. [img]i/expressions/face-icon-small-blush.gif[/img]
