HMF PIPE on predator! need info ASAP
Old Apr 9, 2004 | 12:16 AM
got2gofast's Avatar
Default HMF PIPE on predator! need info ASAP
I got a new HMF pipe for my predator. I put it on tonight but I haven't gotten the quite core yet.
I put on the pipe, a K&N filter, 155 main as recomended, and the fuel screw 3 turns from all the way in, as recomended.
I took it for a ride, but only for a couple minutes. It was 39 degrees. It seems to sputter around for a second when I shift gears and hit the throttle again. Why do you think it sputters? Is it too rich? or do I just need to run it longer? I need help!
MAN, that pipe is so friggen loud, I can't believe it. It sounds like a harley. I need to get the quite core before my neighbors flip.
So far, the power seems like a tremendous difference, In first gear, I can lean forward over the handlebars, punch it and the front end will come right up. I don't even need to put any weight into it in second gear either. This baybe pulls hard!
Old Apr 9, 2004 | 12:22 AM
BT250racer's Avatar
how bad is the sputter?? just a lil one or does it sputter big time..
Old Apr 9, 2004 | 12:27 AM
got2gofast's Avatar
like this--> braaaaaaaaaaaaaaapp-SHIFT- blup blup braaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaap
lol, j/k I guess I don't know what you consider a big sputter. It is definetly noticeable, but if I keep on the throttle hard, it hesitates for about 1 to 1 1/2 seconds. Never did it before.
Old Apr 9, 2004 | 12:33 AM
BT250racer's Avatar
hmm im not complete sure but when i just jetted mine ( was a 130 jet and i thought i was drilling it to a 150 but i think i want a drill bit to big and it sputterd until i got to give it full throttle so i just went to get one ) so maybe try a smaller jet....did u mess with the clip any??
theres a guy on here that has a pred with a hmf i forget his name ill look for it and you could ask him what his set up is.
Old Apr 9, 2004 | 12:36 AM
got2gofast's Avatar
thanks, that would really be helpfull if you could find his name. The HMF websited said a 155 jet was recommended, and someone said they are usually pretty accurate with that. Maybe not though, do you think this is still safe to ride though, it doesn't sound at all like a lean problem does it? Im used to working on snowmobiles, not too familiar with 4 strokers
Old Apr 9, 2004 | 12:38 AM
BT250racer's Avatar
i just did it was akpredator
Old Apr 9, 2004 | 12:40 AM
BT250racer's Avatar
well im not going to say if its safe to ride b/c i dont know alot about carbs and never really messed with a 4 stroke carb other then my truck just wait and see what the toher guys on this site has to say i dont want to give ya any wrong info
Old Apr 9, 2004 | 12:45 AM
badazzpred's Avatar
got2gofast what is your elevation?
Old Apr 9, 2004 | 12:49 AM
badazzpred's Avatar
hey bt250racer can you buy those new maxxis razr's anywhere yet?
Old Apr 9, 2004 | 12:51 AM
BT250racer's Avatar
i know there on the 50th pred and there call irazors but im not sure if your can buy them yet, i didnt really look
