Is anyone using an alternative grease other than the Polaris grease???
Old Jul 20, 2000 | 10:29 AM
atving's Avatar
Is anyone using an alternative grease other than the Polaris grease I realize it takes to different kinds of grease one type for the suspension which is the typical standard grease and the special grease for the drive shafts which is a special type do to the constant movement like a wheel bearing grease so is anybody using a grease which is probably just as good as the Polaris grease...
Old Jul 20, 2000 | 11:02 AM
stevie's Avatar
Im just useing multi purpose grease that i get from my grandpa. He owns a business and sometimes hes nice and throws a tube of grease at me.
Old Jul 20, 2000 | 11:14 AM
atving's Avatar
Stevie are you aware that you have to use a special grease on the drive shaft other than the grease you use on the suspension, because of the constant moving motion of the drive shaft...so are you using the same grease you use on the suspension if so I don't think this is such a good idea...
Old Jul 20, 2000 | 12:09 PM
walexa's Avatar
I use Mobil 1 synthetic grease on mine. It's a high-quality grease that's excellent for all applications from suspension to u-joints, etc. No problems whatsoever so far.
Old Jul 20, 2000 | 12:56 PM
MagnumMudMan's Avatar
atving
I also use the Mobil 1 synthetic grease. It is about 4 dollars a tube around here, but it provide superior protection for all application. I would not use a conventional grease if you ride in mud and water a great deal. The synthetic seems to resist water better than the conventional grease.
Old Jul 20, 2000 | 03:46 PM
stevie's Avatar
I dont have the drive shafts no more. I used to use polaris grease
Old Jul 20, 2000 | 04:14 PM
jeffr's Avatar
I use Amsoil water resistant grease throughout the entire machine,I haven't had any problems and I have used it in all my ATV's and all my friends use it in there's.
99 Xplorer 400
98 Xplorer 300
Old Jul 20, 2000 | 05:30 PM
Hermz's Avatar
Hmm.. i use multi purpose Case IH grease that i swipe from work. I think that if it can hold up on a something that is moving for hours and hours straight, that it will hold up on a drive shaft or anything like that. Don't even try to tell me that you need to use polaris grease. I use polaris 2 stroke motor oil, thats it (i used case ih hy-tran in my transmission, works fine)
Old Jul 20, 2000 | 06:45 PM
PolarisMan's Avatar
My dad just takes a lube everytime were out from the rock quarrie where he works. It is just normal Grease
Old Jul 20, 2000 | 08:18 PM
Bill.Ciliberti's Avatar
I use Multi purpose synthetic grease.Never a problem yet from using it.I dont give a rats *** what Polaris says to use.They all tell you to use ''THEIR'' Genuine parts ect.If we all were to do that,we'd probably have very little money left for the other things on our toys.I go aftermarket on allmost everything I can.SYNTHETIC GREASE ,YES.====Bill
