Whats the difference between dyno ket kit and just changing the Jet?
Old Apr 9, 2004 | 04:30 AM
nez02's Avatar
Default Whats the difference between dyno ket kit and just changing the Jet?
I was wondering what is the difference between just changing my jet and using a dynojet kit? I recently bought a pro-circuit t-4 full system for my 03 scrambler 500 and they told me not to rejet. They want me to install it then see what i need. The dealer says to bump up to a .160 main that that procircuit is full of it. Should i buy just a jet, or the dyno jet kit. And if so how much more work am i looking at installing the dyno jet kit compared to just changing the jet. This is new to me so im sure its gonna be fun.
Nez
Old Apr 9, 2004 | 04:48 AM
71stang99's Avatar
I have the dynojet kit, I wonder the same thing as you, I want to buy a pipe but how does the jet kit fit in? I have installed jet kits before and this one doesnt seem to difficult however depending on the pipe is where things get sticky and thats what drives me nuts
Old Apr 9, 2004 | 09:32 AM
Quadfather's Avatar
I believe that with a Dynojet kit, you get new needles and shims. Dynojets are also sized defferently than stock carb jets, so if you hear someone talking about a (for instance) 160 main jet (stocker), that will end up being like a 128 Dynojet. I think Dynojet sizes their jets by the amount of fuel flowed, whereas other jets are sized (labeled) by the actual circumference of the jet hole. (I think that's right)
I was never a big believer in jet "kits". Just go buy a couple different sized jets from the maker of your carb, and try them until you get the right one.
Old Apr 9, 2004 | 09:34 AM
quadwrench's Avatar
When you are buying a Dynojet kit, not only are you getting an assortment of main jet sizes, but you also are getting a specially tapered jet needle (for better throttle response) and their experience and technical support of what combinations need what sized jets - theoretically they have already done all the "trial and error" in trying the different jet / needle combinations, and all you have to do is install.
Old Apr 9, 2004 | 02:44 PM
BigBadScrambler's Avatar
I agree with your dealer, bump it up to a 160 main and adjust your air/fuel screw so that it is 2 1/2 turns out from lightly seated. Then you may have to do a plug check and see where that got you. When you put a full exhaust on like that, you are going to have to rejet.
merryman
Jan 19, 2016 04:29 AM
Cantbuytime
Aug 17, 2015 06:33 PM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
house1
Aug 9, 2015 10:49 PM
