Any pics of TB 250 trail ported cylinders? And head shaving ?
Old Apr 9, 2004 | 07:33 PM
waynaferd's Avatar
Default Any pics of TB 250 trail ported cylinders?
I'm looking to do my own porting on the new 'Blazer, but I need a good place to start....pics would be marvy. I've done some porting before, so I'm not scared of weilding an air grinder around the motor....Thanks!!
Also, what would be a good amount to shave off the cylinder head to bump the compression up a little, but still be able to rund premium pump fuel? Thanks again....
Old Apr 10, 2004 | 01:21 AM
JEFF10049's Avatar
Default Any pics of TB 250 trail ported cylinders? And head shaving ?
Well The best thing you could do with your head is send it to rick ritter at RcR I think bubba297 does heads too.
both are a good choice the reason I say this is it's more then just cutting some off for best performance the combustion chamber area needs to be squared up in a lathe.
If you want to just cut some off go .025 and you can get away with premium fuel.
Be carfull with the porting the 250 is a piston port engine (no reeds) so theres no room for error you could loose bottom end performance real easy.
Jeff
Old Apr 12, 2004 | 02:02 PM
waynaferd's Avatar
Yeah, that's why I was hoping for some pics of the porting after its all done.....I don't wanna mess it up!!
Old Apr 12, 2004 | 02:32 PM
watzupdog's Avatar
Send it off to bubba or rick. Theve done this for a long time. When I'm ready for what your doing that's what I'll do.
Old Apr 12, 2004 | 03:35 PM
waynaferd's Avatar
Well I've been contemplating the reed valve mod, but if not then probably one of them will have another port job to do.....Messing it up and needing a new jug probably wouldn't impress the old lady too much......
Sandman2.0
Jul 21, 2015 09:03 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Unzzy66
Jul 11, 2015 10:01 PM
Mojave250A
Jul 11, 2015 10:38 AM
