Air box mod
Old Jul 20, 2000 | 04:46 PM
Dirttrash's Avatar
Am I hurting or gaining anything when I take the air box cover off of my 300ex? I know not to get mud or water in it and I know it makes it realy loud.
Old Jul 20, 2000 | 05:07 PM
Mike300EX-99's Avatar
Running with the lid off provides maximum air flow through the filter. You'll have to increase jetting to match the increase in air you gained by removing the lid. A vented air lid is another option. Both are good mods.
Old Jul 20, 2000 | 05:14 PM
Dirttrash's Avatar
What do I need to increase
Old Jul 20, 2000 | 05:25 PM
A bigger main jet, to be had from your local dealer. I'm running a 130, stock was 122.
hot_shoe_cv's Avatar
With the Supertrapp pipe, you're probably running lean right now with a stock main jet. Removing the lid will increase that problem even more, so I would pick up at least two main jets, each one a size fatter that you stock one. Install the bigger one first & test ride, read the plug, and go from there as to whether you need to drop a size. Do it NOW before you do any damage to valves or other components.
If you need info on plug reading you can email me.
I've put it on here a dozen times or more..people are sick of it.
Old Jul 20, 2000 | 11:05 PM
alibaba's Avatar
i wont tell u what to do, but this is what i wanna do. i want to get an aftermarket airbox or another lid, drill holes in 1 and run it like that, then switch it up when im in water.
