razor rotation.... all right?
Are they mounted on wheels? If so then a couple of them were mounted in the wrong direction. If they are not mountd, then there is no problem, just mount them on the rims in the proper way so that the direction arrow is pointed the right way when mounted on the quad. What makes you say that they are all "right" tires? There is no such thing as right or left Razrs. Which side they go on is dependent on how they are mounted on the rims. Good luck
RR1
RR1
yes i got them rocky mountatin mounted on douglas .190... they have a direction arrow and so the one i put on the right spins the right way.. the one on the left however does not... its like that with all 4 of the tires i got?
Then they mounted them incorrectly. One rear tire should have the arrow pointing clockwise, the other on e counterclockwise. I don't really think it will make a huge difference in performance, though, if you run them how they are now. The rear Razr2s don't even have a specified direction. Good Luck.
RR1
RR1
mxer
Jan 26, 2000 10:12 AM
