clutc\belt question
Old Apr 11, 2004 | 12:57 AM
Davinator's Avatar
Default clutc\belt question
Can’t get my belt figured out. When it is just sitting with no pressure there is about 1 1\2 inches of play up and down. I put it in gear and hold the brake and give it a little gas and the belt climbs up the drive clutch and is now in speck. But let off the gas and it goes back to 1 1\2. I thought this was correct because it pulls well and does not sequel and the belt looks good. I looked at a Grizz clutch assembly today and now I see mine can’t be correct. The Grizz belt is tight just sitting there. Mine has never been this way. My belt doesn’t even touch the drive clutch when at idle. The first belt went 1200 miles before it went and that’s the first time I looked in the cover. The new belt went in and I adjusted it the way I described. I thought something wasn’t quite right because of the directions on Nyrocs page on the adjustment. My driven clutch is ok, I think . The drive clutch does not touch the sides of the belt until you give it some gas and it pulls in to the belt and goes. Is my drive clutch way out of shim? If so how do you adjust\shim it. All the shimming I see is the driven clutch. When you put a little pressure on the belt it rides at the top of the driven pulley.
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Supertrapp IDSX exhaust
Primary Dalton Plain\white spring
Secondary EPI black spring
P-700 Belt
28” Mudlites on C's
Warn 4000 winch on front
Warn 2500 winch on back
Headlight mod
Old Apr 11, 2004 | 03:54 AM
Customfabandweld's Avatar
I'm not sure, but I don't think the drive pulley is supposed to be touching the belt, until the stall RPM is reached. You should have about 1 inch of deflection, 1 1/2 is way out of spec. You can't measure it, though, by how much it slack the belt has up and down.
Old Apr 11, 2004 | 10:39 AM
kawakasi's Avatar
Davi
How old is this belt?
Sounds to me like you need a new one
1 1/2 inches is way out of spec
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
