2 stroke oil?
Old Apr 12, 2004 | 01:18 AM
RAJ's Avatar
RAJ
Default 2 stroke oil?
What kind of 2 stroke oil do you guys use? I have been using Polaris syn. I think i'm going to change when I run out, I think I might go with klotz syn. Looks like good oil and smells good also. I need to get my block off kit first, it says per mix only.
Old Apr 12, 2004 | 01:26 AM
Polaris500HO4x4's Avatar
stay with the polaris oil.
Old Apr 12, 2004 | 03:46 AM
JEFF10049's Avatar
Klotz is good oil. Ams oil also makes a good syn.
I think I'm going to change also when I run out of polaris gold syn. to the Ams oil because I want to use my injector and it says you can run it with a injector.
I think the polaris gold is good but I'm starting to wonder if others might not be better after being in my engine a few times and seeing the wear I'm not real impressed with the gold syn. over other non syn. oils that I have ran in the past.
I wonder who makes the polaris syn???
And don't forget RAJ when premixing to jet for it so it's not lean since your adding the oil directly to the fuel that means less fuel to the motor It's being dilluted by the oil.
More oil = less fuel=lean=melt down. And we don't even want to talk about that again.
Jeff
Old Apr 12, 2004 | 08:51 AM
RAJ's Avatar
RAJ
So i'm going have to rejet again? That SUCKS!!!! One of my buddies races his 400ex which has the 440 kit...uses klotz oil. I went to their web site last night a read about it, sounds good. I'm still per mixing it plus injecting it. I'm going through oil fast. I'm paying $38.00 a gallon.
Old Apr 12, 2004 | 09:25 PM
JEFF10049's Avatar
You may not have to rejet when you start premixing the full amount of oil. But keep a close eye on it check the plug right away maybe you should Pm bubba and see what he thinks I know it can make enough differance to need to rejet.
Jeff
Old Apr 12, 2004 | 10:11 PM
RAJ's Avatar
RAJ
I just Pm Bubba and asked him.....thanks for the info.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
