Anyone every run a 18 tooth fron Sprocket?
Old Apr 12, 2004 | 01:21 AM
Entomber's Avatar
Default Anyone every run a 18 tooth fron Sprocket?
I can omly imagine the top end on this thing. Will I need a bigger chain to use it?
Old Apr 12, 2004 | 01:29 AM
SANDMAN430's Avatar
some of the faster guys have said they do.
Old Apr 12, 2004 | 02:05 AM
hoover7's Avatar
I ran an 18 front when I had my 18x11x10 holeshots on.....it did help me but yet i was running 18's.....just becareful cause its awfully close to the case [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 12, 2004 | 02:47 AM
DuneMe's Avatar
I can tell you 17/40 will work. I was running that at Glamis with 22" Haulers so. . . if you are running a 20 or 21" dirt tire and you are riding on packed surfaces at sea level. I can see you possibly needing the 18 in front.
I ran the 16/39 this weekend at Sand Mt. and it pulled perfectly up the face. There wasn't a 4-stroke near me. Drag Shee's are in a whole different league but, I had fun beating up on a lot of modified Shees. Sure if fun beating those!
Old Apr 12, 2004 | 03:08 AM
blue250r's Avatar
Check out my photos pagew there is a gearing chart there that will let you work out alternitaves if you cant use the 18-40 a 17-37 is near enough
Old Apr 12, 2004 | 10:47 AM
SANDMAN430's Avatar
dune me just add in a few dunes rides for the drag shees and that should about equal things up, but your right there a another animal all to them selfs.
Old Apr 12, 2004 | 11:27 AM
ScoobyDFW's Avatar
i've run 17/38 with 22" paddles taking off in second. i've tried 17/35 too.
Old Apr 12, 2004 | 01:08 PM
DS650power14's Avatar
i've got a 18 in front and it sucks, i dont dune so i'm gonna order my 16 tommorow.
but it's friggin fast[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img]
Old Apr 12, 2004 | 01:57 PM
Entomber's Avatar
Yeah I figured I'd just ask. I'm sure the top end is crazy I would like to try it tho...it's just an idea.
Old Apr 12, 2004 | 03:52 PM
DemonDS's Avatar
With living so close to the Bonneville Salt Flats in UT I was always tempted to get a 18 and run it on the flats. truth is though even with a 15/40 combo all out in fifth gear was about as scarry as I want get. I just kept thinking,"If I hit a hole I am toast!!" Couldnt imagine another 10 MPH or so.
