2004 400 sportsman. Is this normal?
Old Apr 12, 2004 | 11:21 AM
walleyed's Avatar
Default 2004 400 sportsman. Is this normal?
I was out riding yesterday and the thing just quit. I thought maybe out of gas so I switched to reserve. I tried to start it but no go. Tried every minute or two for 10 minutes and it finally started. Is it normal to be hard to start after starving it for fuel & switching to reserve?
Or might I have another problem? I'm not really sure if it ran out of fuel. I also dunked it in about 18" of water but that was 10 or 15 minutes earlier[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 12, 2004 | 11:56 AM
Pennyless's Avatar
I have never had a problem starting mine after running it out of fuel. Dunking it in 18" of water should not of had any influence on it. I have all though fouled spark plugs after running in a lot of water. Fouled plugs are always hard on starting.
Old Apr 12, 2004 | 12:13 PM
ktmguy70's Avatar
Yup its normal.. Several posts about it. After you fill up your tank next time, turn it on to reserve for a minute and then back to on, this way your reserve line is full and if you run out, will have enough in it to help prime the pump, which seems to be the problem. It seems that mostly just the newer machines suffer this problem, or am I wrong?
Ron
04 Sportsman 400
Dynojet
Heelclicker w/ White Spring
K & N
Magellan GPS
Old Apr 12, 2004 | 11:04 PM
walleyed's Avatar
Out tonight and all is fine. Ran it on reserve for a bit, then normal & then shut the fuel off and ran it till it died. Started up fine after.
Think your right Ron... Thanks
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
