v-force reeds blew
imhaving $hit luck so far this year with my machine [img]i/expressions/face-icon-small-sad.gif[/img] ..went for a ride after work today and flying down the trail i heard a pop and my machine bogged out and coasted to a stop,i checked my plug and there was a piece of carbon fiber between the resistor and the threads of the plug.took my reeds out and 1 of the fins is gone.how long do v-force reeds usually last?mine are only about a year old..im worried about that pedal inside the motor,should i be?i can buy replacment pedals right?
The rest of your reed petal should be in the pipe.I have had this happen to me also.If you have the ones that are adjustable you need to set them in high tension.A year and a half is about normal life ,as the tips will begin to chip off.You are looking at around $50 for some new petals, you can't just buy the ones that are damaged you have to get the whole set.
should i take the pipe off and take it out?it was only half a pedal that broke off from the center piece of the cage.when i ordered them i thought the dealer said they were vforce 2's but im not sure,they only say vforce on them.they dont seem to be adjustable at all?the other pedals look like they are new,no chips or cracks anywhere..
Most definately have them on high tension, make sure the screws are tight on the adjustment as well. Didn't get mine completely tight once worked loose and went to the low tension setting and they didn't last long after that!
It also doesn't hurt to run the $19 reed spacer. Heat and vibration are the worst enemies of carbon fiber...the spacer gets them a bit further away from all the action of the combustion process. [img]i/expressions/face-icon-small-smile.gif[/img]
yeah mine seem to be adjustable,setting the pedal clamp on high tension would be to slide it which way?
thanks for the help guys..i already have the reed spacer modquad [img]i/expressions/face-icon-small-smile.gif[/img] thanks for the suggestion anyway though..
jrooker6
Apr 23, 2016 07:36 PM
