Toe out Scrambler 90
Old Apr 12, 2004 | 11:00 PM
Cammer's Avatar
Default Toe out Scrambler 90
Hey guys,
Any suggestions on how to do this? The owners manual says how to check it but not how to fix. Says take it to the dealer. The tires are toed out almost an inch and s/b 1/4 inch.
Thanx
Old Apr 13, 2004 | 12:51 AM
csamayfield55's Avatar
Before you start adjusting the toe, make sure the ball jount on the steering knuckle is tight. I had my sons come lose twice now on me and it makes the steering go all hinky
Chris
Old Apr 13, 2004 | 12:20 PM
Cammer's Avatar
Funny you mention that. I tightened the bolts under the ball joint and it cleaned up the slop in the steering. But, the one ball joint at the steering knuckle seems loose on top when I grab the steering rod. It also didn't fix the toe out issue. Any other advice?
Old Apr 13, 2004 | 08:38 PM
Forgot to mention in my PM but if there is slack in the joint then you need to get another one and change it out before you try to toe it
Chris
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
