Belt exploded!!!!!
Old Apr 13, 2004 | 06:25 PM
Crankdog's Avatar
Default Belt exploded!!!!!
Today while I was riding down the road, a terrible noise came from under the belt cover, no warning light, no nothing, and the belt deflection was set. Sure enough when I took off the cover the belt was nothing but 1" pieces. Never heard of this one before on the forum. Just wondering if this happened to anybody else, and if it caused any other problems. I did notice that the primary clutch had a groove worn in it, does this have to be replaced along with the belt? If so is it possible to lathe the clutch faces like a rotor, cause I bet these things aren't cheap. Any thoughts would be appreciated.
Old Apr 13, 2004 | 07:01 PM
CrekRunner's Avatar
Had this happen to me but it was because i made my belt snorkel too small. Belt overheated and tore it to pieces. Hasnt happened since.
Old Apr 13, 2004 | 08:35 PM
nyroc's Avatar
Crankdog, Alltoys has been able to machine his clutch faces. I imagine a lot of places can do it. Seems simple enough. Snowmobile shops do it all the time (or have it done somewhere else).
However, a certain amount of grooving is OK. You may decide that yours will still work with it.
I had a little groove at 450 miles (belt was slipping bad), but when I replaced my belt and set it too tight, the groove basically disappeared after 900 or so miles. The tight belt wore the pulley kindof straight and even. Strange, but good. That belt is still slightly tight.
Old Apr 19, 2004 | 06:52 PM
Davinator's Avatar
Just lost another belt to explosion. It may have been on the edge of spec, but those 28” mudlites killed it. Started to squeal on take off after the tires and it didn’t take long. I re-shimmed it after I heard it making noise after I was done riding that day. It was to late. Brought it in to low side of spec and the next ride she went. It was showing signs of wear. That’s the second one to go while I was wide open. If you haven’t had this happen to you yet, it sure sounds like you just destroyed your ride.
DG Holeshot
DG Snorkel
K&N Filter
Dial-A-Jet
Supertrapp IDSX exhaust
Primary Dalton Plain\white spring
Secondary EPI black spring
P-700 Belt
28” Mudlites on C's
Odyssey 925 Dry cell battery
Warn 4000 winch on front
Warn 2500 winch on back
Headlight mod
Back-up lights
Old Apr 19, 2004 | 08:33 PM
LuvDaMud's Avatar
I had mine explode at 2500 Km(1500 Miles) while I was full out on a flat dirt road. Was not impressed!!
had to walk about 5 miles to my truck. It went like yours; in 1inch peices and all the cords just wrapped inside the clutch (what a mess). They replaced it on warrenty because they had checkes it just the previous day and it had no signs of wear or slippage. Could not get an explanation from them as what caused this.
_____________________
P 650 red 2003
Holeshot Module
Dalton Clutch Springs
ITP C-Series Cast Alum Rims
26in Bear Claws
Full Equiped
Old Apr 19, 2004 | 09:35 PM
SHOTGUN's Avatar
Happens once in a while, mostly due to heat build up. check your air intake and exchaust for the clutch, to make sure it isn't covered by the rubber around the steering column or under the seat.
I'm going to install a piece of aluminun around the top of my clutch cover. just for an extra safety measure, not sure the plastic cover would contain a piece of clutch, if when the belt let go it took the clutch out too, at 10,000 RPM's.
Old Apr 19, 2004 | 09:55 PM
RancherS01's Avatar
My brother in law had the same thing happen a week ago, doing about 60 km/h and it snapped into 1 inch pieces, hardest part was getting the cord unwrapped from the driven pully!! Belt was loose before hand though, very loose. Had to order a new sheath too as the bushing wore out and it was wobbly. Might want to check that yours fit tightly together Crankdog.
Old Apr 19, 2004 | 10:06 PM
hammerman's Avatar
It would be a good idea to change the belt every 1000 miles. I changed mine at 1000. the old one was
cracked in the groves on the lower side.
Old Apr 19, 2004 | 10:14 PM
LuvDaMud's Avatar
Yeah, thats good . But is'nt a belt supposed to last a lot more than 1000 miles? Cause that would mean that I would be going through 2 belts a year at $140 Can. a pop.
Old Apr 25, 2004 | 11:03 PM
sicnj's Avatar
I broke my belt today full out on the streat 1050 miles two weeks after putting in secondary spring. i havent had a chance to open it up yet but im prayong that its only the belt.
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
