engine froze, now what?
Old Apr 13, 2004 | 10:09 PM
ezzell's Avatar
Default engine froze, now what?
I have an 85or 86 klf 185 and I sprayed carb cleaner thru the carb as it was running and an alful noise sounded and it just froze up... now what am i supposed to do? can it be fixed? where do I start....
Old Apr 14, 2004 | 10:21 AM
ezzell's Avatar
can i get a little help please?
Old Apr 14, 2004 | 11:25 AM
NovaKaw650's Avatar
You must have gotten too much spray in one shot; it may have hydro-locked the engine and bent/broken a piston/crank/rod. Another possibility is that the cylinder walls washed clean of oil and seized the piston. Either way, it needs to be torn down to determine what happened.
Old Apr 14, 2004 | 11:32 AM
newbeatle's Avatar
I agree with NOVA... but it is very unlikely that you sprayed enough to hydro-lock the cylinder... 2 cycles are extremely sensitive to dry cylinders, & that carb cleaner, was sure dry out your cylinder... sorry to say, but I'm betting you've got a top end rebuild in your future... I just hope that it didn't damage everything bad enough to have to throw everything away... you may also have an over bore in your future...
Old Apr 14, 2004 | 02:36 PM
schl48a's Avatar
take the head off and spray some wd 40, lite oil or something to lube it and let it set for a couple hrs. and then try turning and if it won't turn try a block of wood and gently tap the wood on top of piston. keep it lubed.
good luck.
Old Apr 14, 2004 | 07:48 PM
mahnster's Avatar
Im pretty sure that its a four banger not a two stroke, because i have one.
Old Apr 14, 2004 | 09:05 PM
ezzell's Avatar
yea its a 4 stroke
Old Apr 15, 2004 | 12:17 AM
mahnster's Avatar
Well when my bayou goes caput im gonna put my honda 350 four motor in it, lol thats right a 350 four cylinder. Bayou is definately gonna be pimp with dual pipes.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
timster911
Jul 13, 2015 01:57 PM
