scrambler clutch
Old Apr 14, 2004 | 11:27 PM
scamman72's Avatar
Default scrambler clutch
what is the best way to tighten my clutch belt. i can squezz it in the middle and they almosttouch. put a new belt on this past weekend and it went on real easy.
Old Apr 14, 2004 | 11:35 PM
Bradracer18's Avatar
You can't tighten the belt(atleast I don't think), you must have gotten a wrong belt. They usually fit somewhat tight.
Old Apr 14, 2004 | 11:48 PM
OffRder15's Avatar
Bad clutch alignment?
Old Apr 15, 2004 | 12:29 AM
BigBadScrambler's Avatar
Check the distance from the center of the primary clutch to the center of the secondary clutch. It should be 10". If not, then your clutched are probably out of alignment. This may be due to faulty or loose motor mounts or tranny mounts
Old Apr 15, 2004 | 12:38 AM
WhiteLightning's Avatar
What do you mean you can't tighten it!! To tighten your belt you need to remove shims in the secondary that space the helix less shims tighter belt, but be carefull you must always have one shim. Also belts really do not last that long, unless you get an aftermarket. Hope this helps
Old Apr 15, 2004 | 08:48 AM
scootergptx's Avatar
Supersock
Hired Gun!
Been runnin' the same belt for 4years. Only changed it because I was putting in new spring and figured, hey I'm here anyway.
Old Apr 15, 2004 | 09:13 AM
POLARISFREAK's Avatar
I don't think removing a shim in the secondary unless somebody has added some will take up that much deflection, something doesn' t seem right. I'd definately check to make sure I got the right belt. I would then check the clutch alignment and go from there. The belt should stick about 1/8 in out of the secondary clutch
Old Apr 16, 2004 | 11:24 PM
im sorry if somethig does not sound right POLARISFREAK, but I guess i could call Polaris and tell them that there owners manual is wrong and you are right. The stock secondary comes with three shims, and yes if you add a clutch kit from HPD you will add shims every clutch is different, there is know way that moter or tranny could have shifted unless something like a motor mount or tranny mount was broken. If one of them was removed I could see it but other than that, Mine have been in the same place for years and I ride hard, so feel free to contanct POLARIS INDUSTRIES and let them know they have a missprint.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
