Predator Maintenance
Old Apr 15, 2004 | 07:40 PM
2004TroyLeePredator's Avatar
Default Predator Maintenance
I was just wondering how often you guys change your oil, grease all the nipples and lube your chain.
I've heard many different stories from people and want to know the right time periods.
Old Apr 15, 2004 | 07:58 PM
modquad's Avatar
Basically I give each zerk at least one squirt after each wash. Then I carefully pull back each of the steering pivots (don't forget the short Pro-steering pivots)and give them a squirt of Tri-flow. I also catch the chain w/ the Tri. As for oil changes, 50-100 hrs depending on what you're doing w/ the machine.
Old Apr 15, 2004 | 09:42 PM
Hozed's Avatar
[img]i/expressions/face-icon-small-shocked.gif[/img]
what!?!?!?!?
geez modquad...
every 10 hours!!!
its the cheapest way to keep your engine running clean... oil breaks down after awhile... and 50-100 hours is WAYYYY past its break down time.
i change mine quite often... call me crazy... but i like my oil looking only tinted black....
Old Apr 15, 2004 | 10:42 PM
modquad's Avatar
Only tinted black, often times only means there's a level of oxidation. In this age of sythetics, and semi-synthetics, you can run the oil for longer periods of time. Periodic filter changes (or cleanings, I use the Scott's Performance re-useable stainless) is still a good idea. Don't want to hit that filter bypass mode. Also, I run the CFM +1 qt oil tank. That matched up with all the cooling additions, the machine is tasked that much less. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 15, 2004 | 10:50 PM
Hozed's Avatar
id still change it atleast every 20 hours...
Old Apr 15, 2004 | 10:57 PM
pudljumpr's Avatar
The yamalube in my yfz seems to hold up well, but I was never a fan of the PS-4. If running that, I would recommend changing every 10-15 hours. I changed oil in the pred every other race. And I grease it after every wash, and chains get lubed after every wash. Water and soaps can get in places, and rust is not your friend. Lube after every ride!
Old Apr 15, 2004 | 11:15 PM
Hozed's Avatar
do you use the 10-50R oil or 20-40?
dannytas
Sep 26, 2017 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
caveeagle
Sep 19, 2015 01:20 PM
Elkaholic
Sep 6, 2015 02:44 PM
