Knocking problems
Old Apr 17, 2004 | 08:06 PM
oldcrow's Avatar
Default Knocking problems
A buddy wants me to take a look at his Polaris Trail Boss 250 4X4. It has a 250cc 2 stroke single cylinder and when it idles it sounds like a 2 cylinder running on one and it knocks real bad.
My first impression is the timing is way off.
Any ideas?
Old Apr 17, 2004 | 11:33 PM
DGpolaris2346's Avatar
Polaris engines are known to knock. I know mine knocks and ive had it checked out but nothing was wrong with it so i just bought a louder pipe and i dont here it anymore.
Old Apr 17, 2004 | 11:55 PM
DGScrambler400's Avatar
good problem solving
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 18, 2004 | 12:31 AM
RAJ's Avatar
RAJ
oldcrow, as far as the timing....no such thing on a 2 stroke. they do not have a cam. Mine also knocks...
Old Apr 18, 2004 | 01:27 AM
JEFF10049's Avatar
It may be piston slap. mine knocks from this no big deal[img]i/expressions/face-icon-small-smile.gif[/img]
Jeff
Old Apr 18, 2004 | 02:45 AM
mistertinker's Avatar
two strokes have no ignition timing?
Old Apr 18, 2004 | 02:29 PM
oldcrow's Avatar
WHAT??? Ignition timing is what is used to insure the spark plug fires at the correct time.
What produces that spark? The stator, flywheel, coil, ect.
Same as a 4 stroke.
You are not always able to adjust it but it is there.
Old Apr 18, 2004 | 05:01 PM
Dobie's Avatar
I have a 04.5 500HO and it sounds like a diesel! I otherwise love it though. Dobie
Old Apr 19, 2004 | 09:33 AM
quadwrench's Avatar
The stator plate is adjustable for ignition timing - a real pain to do since the flywheel has to be removed every time to make even the slightest adjustment.
From experience - especially if it has a Wiseco piston in it - they will knock to some degree. A lot of the Wiseco knock is actually piston slap as it requires a greater piston skirt to cylinder wall clearance than an OEM piston.
Something else that can cause a "knock" is the upper rod bearing may be getting a little sloppy
Old Apr 19, 2004 | 10:04 AM
badazz400's Avatar
my bike has a serious death rattle and its just been rebuilt. guess thats just the nature of the beast. [img]i/expressions/face-icon-small-wink.gif[/img]
ross
