prairie 650 overheating
Old Apr 18, 2004 | 02:19 PM
cuzz's Avatar
Default prairie 650 overheating
got an 02 650 praire which I bought new in canada. the last two dice runs I have been on the thing overheated. the first time it blew the line that routes coolant to the carbs. I replaced it and cleaned the radiator but it did it again yesterday! It was blowing coolant out the cap. what the heck is up with this machine, i am ready to get rid of it!!
Old Apr 18, 2004 | 04:58 PM
meangreenmudmachine's Avatar
You may need to clean out your radiator, just get a regular garden hose with sprayer and spray through the radiator from front and back. Most will run hot when radiator is clogged.
Also try the new dyna cdi, it is supposed to help the bike run cooler.
You could also try some of the heat fighter kits, just check around there are a ton of them.
Good luck
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
