jet from HMF....could they have sent the wrong one or im just dumb
Old Apr 19, 2004 | 11:06 PM
quiganibbler's Avatar
Default jet from HMF....could they have sent the wrong one or im just dumb
i put an slip on exhuast from HMF...i went to install the jet, got the carb all apart. so im lookin at the jets already in the carb and look at the ones that they sent me and none of the ones on the carb look even close to the size of the new jets....i took the highspeed jet out with the tube and everything but it doesnt fit inside that little tube...is this the jet that im supposed to replace or another one on the carb which i just dont see?!?!?!?!?
Old Apr 19, 2004 | 11:19 PM
Haulinonthedunes's Avatar
The jets are on the bottom of the carb. Should be 4 screws holding the bottom bowl on and when u pull that off u should see the float. Then between the deals on the float there will be two jets a pilot jet which is about 3/4 inches long and then right in the center there should be a little short round stubby one and that is ur main jet. Hope this helps. [img]i/expressions/face-icon-small-smile.gif[/img]Lance
Old Apr 19, 2004 | 11:25 PM
the one that i have to replace ur sayin is the one inside the little tube with small few holes in it?
Old Apr 19, 2004 | 11:34 PM
Yes the one u are explaning is the pilot jet. It is very well possible that they sent the wrong one because i ordered a new pilot jet from my local atv shop and it was just alittle to big. Are u running the stock carb? What size is the pilot jet they sent u? I would call them and let them know about this and see if they will get u a different one or maybe ur local atv shop will have one. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 11:37 PM
when i orderd the exhuast they asked me what size jet do i have i said i dont know so they sent me the only 2 that it could be...if it was one put in the other and so on.....they sent me a 175 and 125 jet...there short with fat head...well fatter then any other jet on there...and doesnt fit in that tube...and yes i am running stock carb
Old Apr 19, 2004 | 11:42 PM
Sounds like to me that u are trying to put a main jet in the pilot jet spot. Correct me if i am wrong. Did they send u a pilot jet or a main jet? Just asking to make sure. But it is very easy to install jets and i dont think u could mess up, maybe they did send the wrong ones. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 11:43 PM
Private message me ur e-mail and i will send u a picture of a main jet and a pilot jet so that there is no confusion. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Old Apr 19, 2004 | 11:58 PM
is it really that bad to just run the stock jet??
Old Apr 20, 2004 | 12:01 AM
Well without the correct jetting u can damage the engine if it is to lean and u can also hurt it if it is very rich, but it is ok to run it if it is just alittle rich but not alot. Never run it if it is lean, it will damage it badly. I sent the picture of the jets. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
pics were hard to see but from what it looks like...they sent me the main jet...is there a jet that looks like the main jet but smaller inside that little tube that ur sayin is the pilot jet??
