26"tires on foreman?
Old Apr 20, 2004 | 04:21 PM
sharpie's Avatar
Default 26"tires on foreman?
just wondering, would i run into any problems if i put 26 inch tires on a stock foreman ES? also, could i go with 10" wide in the front and 12"wide in the rear on the stock rims without a lift or any other mods? also, does anyone have any good/bad opinions on dirtdevil XT tires?
Old Apr 20, 2004 | 05:35 PM
billiebobber's Avatar
I put 26 in Black waters on a 2002 Honda 350 E.S. Rancher mounted on 12x7 atp delta steel rims They work just fine But could use a little more engine power in 4th and 5th gear. On a Foreman there should be no problems.
Ride on Keep safe.
Old Apr 20, 2004 | 07:47 PM
Buzzman's Avatar
I have 26 inchers on my Foreman Es.....no problems. I have 10" on the front, and 12" on the rear.
Old Apr 20, 2004 | 09:15 PM
Yamaha660R's Avatar
You can even run 27's if you feel like it. 26's fit without problem.
Old Apr 21, 2004 | 02:02 AM
sharpie's Avatar
so does anyone know of any cheap power upgrades to help keep these tires spinning in the deep stuff? i would love to get a pipe and the works, but money wont allow that. filter? jet kit?
Old Apr 21, 2004 | 02:45 AM
Coyotechaser's Avatar
If you get the DD's X/T post some pictures. I am think about getting them on my Foreman. I was going to get 589's but they've jumped up in price a bit. I don't really want the Mudlites. So that leaves the Mudrunners and DD's. DD's are cheaper.
Old Apr 21, 2004 | 09:27 AM
Sparkey's Avatar
It may change your speedometer / odometer readings a littlle. Any one got experinece with this?
Old Apr 21, 2004 | 02:44 PM
HwyFlyer's Avatar
I put the 26" Dirt Devils on my 04 Rancher 4x4 AT and have not had any problems with clearance, I have noticed some power loss due to the added size but not much. I am happy with the Dirt Devils riding mostly trails with the ocassional mud hole, they also did well in the snow.
Old Apr 22, 2004 | 08:33 AM
Buzzman's Avatar
It changed my seedometer and odometer about 10%, but now it is right on with my GPS. I guess it was off a little to begin with.
Old Apr 27, 2004 | 10:17 PM
sharpie's Avatar
so can i run 10" tires on the front 8" rims and 12" on the 10" back rims? i belive that i can, but i can never be too sure.
