How do you know when it is time to do a rebuild?
Old Apr 20, 2004 | 04:24 PM
Randalscandal's Avatar
Default How do you know when it is time to do a rebuild?
what are some signs of when you know that you have to do a rebuild??
Old Apr 20, 2004 | 05:28 PM
MikeyBoyesq's Avatar
Here's one: Your bank account gets large enuf to afford a Big Block Kit!
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 20, 2004 | 06:39 PM
nyroc's Avatar
Wont start due to low compression.
Clanking sound due to piston, rod, bearing, ring, valve, valve guide problems.
No oil pressure.
A lot of blowby causing oil to blow out the tube even though the oil isn't overfull.
Oil in the coolant. Coolant in the oil. Oil in the exhaust. Coolant in the exhaust. Leaks and cracks in stuff.
Sometimes you take the head off and find problems only in the head. So, that is all you fix.
Sometimes there is a need for speed like Mikey said.
Old Apr 20, 2004 | 06:44 PM
newbeatle's Avatar
for me it was a warped head / bad head gasket ( from getting too hot too many times )... white smoke ( actually steam ) out of the exhaust ... & why not rebuild it, if you are opening it up, if you are planning on keeping it ???
Sjrpp
Jun 2, 2019 07:25 AM
kelleycully
Sep 15, 2016 02:57 AM
traumajunkie
Jul 5, 2015 03:03 PM
ranvette
Jul 4, 2015 06:13 PM
yambam13
Jul 4, 2015 01:49 PM
