Effects of Compression
Old Apr 21, 2004 | 12:05 PM
NLWarrior01's Avatar
Default Effects of Compression
Hey,
I was just wondering what effect would be had by changing my stock piston to a 10:1 or a 10.5:1 higher compression piston? What else has to change along with the piston? Is there much of a gain by changing just the piston?
Any opinions welcom [img]i/expressions/face-icon-small-smile.gif[/img]
Thanks,
Trev
Old Apr 21, 2004 | 03:19 PM
warrior387cc's Avatar
i noticed a big diff in mine but i have a much higher comp than that and i did all my
mods at the same time
Old Apr 21, 2004 | 04:15 PM
Doctorturbo's Avatar
GOT BOOST!
Half a point of compression, not much at all. Sure you will pick up some power, but very little. It's hard to do just one mod and pick up a bunch of power. To get more O2 to the engine you have to do a bunch of mods at the same time to work well.
Look at it this way, if you put a big carb on to flow a bunch of air, you still have a stock pipe and cam with restrictions.
Nitrous and super/turbochargers are two exceptions to the rule.
Old Apr 21, 2004 | 04:19 PM
Yeah, I figured as much. Not really worth it to me.
Old Apr 21, 2004 | 06:02 PM
Shav0's Avatar
plaining the head will get you farther power wise then going to a 10.5
Old Apr 21, 2004 | 06:12 PM
garyc660R's Avatar
Planing the head is not really a good idea on a 4 stroke (timing chain). More compression actually compresses air and fuel more for a more efficient and powerful burn.
Gary
Old Apr 21, 2004 | 07:50 PM
NovaSS's Avatar
RULE OF THUMB FOR 4 STROKERS >>>>>1 point of compression is worth about %.04 in power ( torque). So if you have 20 LB FT of torque going up 1/2 point will give you almost an extra 1/2 LB FT!!!
Old Apr 22, 2004 | 08:47 AM
garyc660R's Avatar
HP is a form of torque. If you are gaining torque at any RPM, you are gaining HP. More compression is almost always a good thing. Some 2 strokers do not like too much compression because the RPM ceiling is lowered for that application.
Old Apr 22, 2004 | 09:05 AM
HP = torque(lbs-ft) x rpm/5252
So if that rule of thumb is true about compression .. then going from stock compression on the warrior at 9.2 up to a 10.5 is a gain of 1.3 ...
20.3lbs-ft stock .. I would gain roughly 1.05 pounds of torque. Which, at 6000rpm equates to ... 1.2hp at the crank.
What about reliability issues? And where rougly would I be I wonder once I've installed my new filter, rejet correctly with my FMF pipe? Questions questions questions [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 22, 2004 | 09:12 AM
garyc660R's Avatar
Reliability? Any time you ask more from an engine (power wise) reliability will lower.
