banshee?
Old Apr 21, 2004 | 03:08 PM
blasterrider's Avatar
Default banshee?
how much will it coast to get a banshee rebuilt and bored 90 over . and where would be the best place to send it to thanx
Old Apr 21, 2004 | 03:21 PM
Hiram's Avatar
Default banshee?
.90 over that's alot you need to start looking instead to reselve and start back at stock
Old Apr 21, 2004 | 03:38 PM
Default banshee?
well it is stock and i always heard that when u go and rebuild a 2 stroke thats the good time to bore it out ? how far do u think i should bore it out then?
Old Apr 21, 2004 | 03:42 PM
runts's Avatar
Default banshee?
Well when you go and bore it out just bore it .20 over or .40 over because you dont want to bore it so
much that you start having heat problems and when you go rebuild it again you can still bore it somemore
with out resleeving.
Old Apr 21, 2004 | 03:46 PM
sAyIt_fmf's Avatar
Default banshee?
Typical prices are around $30 per cylinder for the bore job ......standard wiseco pistons run about $150 for the pair.
Then you will need a top end gasket kit (base and head) for around $30
I would also change the wrist pin bearings for around $25
That should do it.
And...as mentioned....I would do .020 over...that will leave you plenty of room for future rebuilds.
Old Apr 21, 2004 | 03:50 PM
warrior387cc's Avatar
Default banshee?
yea like fmf said if you go to big you won't be able to rebuild
and a lot of guys rebuild every 2 years no questions asked.
Old Apr 21, 2004 | 05:14 PM
Default banshee?
well my friend is the one who told me abought it and i think he sed it was still stock and its black and white 98 modle and all it needs is a rebuild and its in good shape
Old Apr 21, 2004 | 05:21 PM
2004LEBANSHEE's Avatar
Default banshee?
HOLD ON MAN!! If it's never been bored before you probably dont need .90 over, bore as little as possible. If you can get away with .10 DO IT. .90 isn't going to make you any faster maybe 2 HP. THe only bore that will do anything is a big bore. .90 over is your last bore dont use it unless your cylinders are really screwed up and you need it. If you want HP get a port job. PLEASE DONT GO .90 UNLESS YOU NEED TO.
Old Apr 21, 2004 | 05:48 PM
Default banshee?
well im just going by what my friend told me cause he has a shee and that was his first bore job on it. but i might just get it rebulit for now and then bore it out later on down the road so i can get use to its tock speed for now and bore it out next time it needs a rebulid
Old Apr 21, 2004 | 05:50 PM
Default banshee?
well what do u shee owners think i should do besides getting it bored over while its getting rebulid
