Any Modded Z250's out there?
Old Apr 21, 2004 | 03:34 PM
RaptorOwner's Avatar
Default Any Modded Z250's out there?
What hp gains did you or do you think you got? Also, what have you done to it?
Thanks
Old Apr 21, 2004 | 06:07 PM
z250freak's Avatar
I think the person who has the most stuff is zquader.
Old Apr 21, 2004 | 07:51 PM
zquader's Avatar
I have alot of aftermarket parts, but only a few to help the motor. The DMC pipe , modded air box and jetted may have gained a few extra ponies!!! It realy woke up the bottom end and especialy the mid section. I have the 6 ply razrs on the rear and have know problem sliding through the corners, and the 3+6 offset helps alot with stability.
If you want any other info just ask !!
It may seem like I have alot into this lil quad but I bought it for $3600 otd, so with all the extras I am just over what some other dealers are selling it for OTD
Old Apr 21, 2004 | 08:17 PM
Do you have holes in your airbox or what mod did you make to it? Also, the pipe, does it not come with the spark arrestor or do you have to purchase that extra?
Thanks!! I am trying to get my Z250 up to par so I dont have to buy a new one.
Old Apr 21, 2004 | 08:44 PM
Perwho's Avatar
Yoshi slip-on and just bolt ons here. Brought the low to mid range to life pretty good![img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 21, 2004 | 10:08 PM
zquader's Avatar
The pipe comes with NO spark arrestor or quiet core ! the pipe is very loud without the quiet core , close to 104 dbl !
As for the air box I removed the plate on the inside of the lid, so that the air will go directly into the box, I also installed the twin air filter.
Old Apr 22, 2004 | 12:15 AM
SpankyLowe's Avatar
Just a DG slip-on for me and the same results as everyone else,really makes a differance on bottom and mid range..........
Old Apr 22, 2004 | 09:30 AM
SuzukiZ250Kid's Avatar
I don't have any mods. to help the engine on mine, but it sure does look fast[img]i/expressions/face-icon-small-cool.gif[/img] Just check out my pics page.
Old Apr 22, 2004 | 01:40 PM
BrocksZ's Avatar
I just took the baffle out of the stock exhaust, couple airbox mods., rejetted, and widened it out about 3" and got the same results as everyone else. I don't understand buying the DMC full exhaust. The header pipe is exactly the same as the stock one. Same as just buying the slip on right? When an exhaust doesn't require jetting that means its not allowing more air flow, which means your not getting any more power out of it. Whats the point? I think I might go with the Alba slip-on. The best thing I did is the spacers and flipping the front rims, made a huge difference in handling.
Old Apr 23, 2004 | 12:44 AM
TomZ250's Avatar
yah i plan to mod mine too, but should i get the white brotheres e series or alba slip on?( cant have too loud)
what is the diff..between the loudness and the performance?
thanks
tom
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
