Where can i get.......
a temprature gauge to check the exhaust temp on the header pipe without getting an egt meter or whatever that is called, i just want something that can handle temps up to 1500degrees.[img]i/expressions/face-icon-small-smile.gif[/img] Thanks Lance
A temperature gauge to check the exhaust temp is an EGT gauge. EGT = Exhaust Gas Temperature. Usually there is some type of probe they goes into the header. Simple ones you just drill a hole, insert the probe and it uses a pipe clamp to secure it. Other weld on a bung to the header and the probe threads into it. I don't know how you can get EGT with out a EGT gauge.
They do have Handheld Infrared Pyrometers. It looks like a timing gun, you point it at what you want to read, and it tells you the temperature of that item. I don't think it could be used to get an EGT. They are more used for tire or brake rotor temps.
I assume you are looking into EGT gauge to help tune your alcohol adventures. Would an A/F monitor work? I think most Air/Fuel Ratio monitors use a Oxygen sensor. So you would still have to install a probe into your header. I don't think most Oxygen sensors are compatible with leaded fuels, I don't know about alcohol though.
Check out Jegs for gauges
I did some looking and it is the egt meter that i am looking for. On the jegs site it had the probe and all that stuff for $97 but where do u get the gauge to read the temp? [img]i/expressions/face-icon-small-smile.gif[/img] thanks lance
Gauges
Here are all the gauges jegs carries. You will find that AutoMeter makes a bunch of different lines of gauges, basically the difference is style.
I think the one that matches the stock tach the best is the Auto Meter Pro-Comp Gauges. If you scroll down the page you will find the EGT gauge.
Originally posted by: Haulinonthedunes
I found one at jegs for $135 so that is probably the one i am going to get. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
Would a Air/Fuel ratio monitor work? Something like Holley Air/Fuel Ratio Monitors or Edelbrock Air/Fuel Ratio Monitors
Pyrometer Gauge
Will this gauge work for the DS. ScoobyDFW said to go with the K- kit so will this z-series work or is this considered as a k-kit or whatever that is suppost to mean. [img]i/expressions/face-icon-small-smile.gif[/img] Lance
