28 or 27
Old Apr 23, 2004 | 11:04 PM
Grippo's Avatar
Default 28 or 27
I have a 2004 Foreman 450ES I am going to be doing a lot of upgrades to it and am wondering if you would recomend 27" or 28" tires. I am going to be going with the ITP 589's mounted on Type 4 C-Series rims. I know somebody with 28's and it is an awsome setup. Along wiht other mods he has a lift kit and wheel spacers and the only problem with almost 4000 miles is premature wheel bearing failure. I am thinking about a similar setup but would like to hear of any other problems encountered. I've heard of CV joint problems but he has never had any. With either setup I would be putting in a Jett kit, K&N air filter and a slip on pipe to get some more power. I have also heard of a kit from highlifter that engages the cluth at about 500 rpm's higher which should help in the mud b/c the quad would be higher up in the power curve. Any other suggestions? Thanks guys
Old Apr 24, 2004 | 10:30 AM
lohman's Avatar
Default 28 or 27
Grippo - I had the same question over the winter, after many forum searchs and discussions, I decided to go with the 27". I was not really wanting to make any mods other than a lift kit. If you are going to install a pipe, jet kit and other mods, go for the 28"(s).
Here are some links to some pics I just took a few weeks ago as I finished my winter project up.
Front View Pic
Side View Pic
Side View 2 Pic
Front Wheel Close Pic
-lohman
