I need help, tip on service person.
Old Apr 24, 2004 | 12:08 AM
ram51's Avatar
Default I need help, tip on service person.
I have a Blaze that has a engine rebuild, had it done, and put the engine back in myself. Now I
can't get it to start, no fuel from the injectors, I don't have the software, cable to diag problem.
Called ATK, they say throttle body has to be calibrated to the injectors?? I live in Indiana and just want to get this quad running so that I can sell it, does anyone know where I could take this Dale to get it fixed?
Anywhere in a 300 mile distance from Indy.
Thanks...
Old Apr 24, 2004 | 12:12 AM
Sandgod's Avatar
Try R & S P E R F O R M A N C E . N E T Your motor should still start and at least run.. Look for other problems..
Old Apr 24, 2004 | 04:09 AM
WISTECH's Avatar
I think the most common no start condition after motor install is incorrectly installed ,unplugged,sensorsand fuel injectors. Some connectors will fit in other plugs,please check them,they are labeled. Make sure the pins on the injectors arent bent and you didnt install the battery in backwards. It can and has been done before.Do the obvious first. All grounds connected? Kill switch on? Are the fuel tank fittings firmly connected.
Customer Service #1
May 15, 2020 08:46 AM
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
