NEED HELP ON BAYOU CAM SHAFT
Old Jul 25, 2000 | 09:31 AM
snakeyes93's Avatar
hi,
the cam shaft on my bayou 300 needs to be replaced. somehow the ledge which the top cam gear broke. i've got the engine down to where i can start pulling the bearings, etc. out. please if anybody knows how to take out a cam shaft please give me the steps to do it. thanks alot
john
Old Jul 25, 2000 | 10:58 AM
Tree Farmer's Avatar
While I highly recommend investment in a service manual,
Remove camshaft cover. Line up cam chain sprocket mark with index on head (about 11:00, I think). Remove camshaft chain tensioner. Remove camshaft sprocket bolt & sprocket, disengage from cam chain, BUT: TIE A STRING OR WRAP A WIRE AROUND THE CHAIN SO YOU DON'T DROP IT INTO THE ENGINE. STUFF A RAG IN THE CHAIN TOWER SO YOU DON'T DROP THE BEARING RETAINER SCREWS INTO THE ENGINE. Remove the bearing retainer screws and retainer. Screw the camshaft sprocket bolt into the camshaft, use bolt as handle and pull out camshaft and bearing.
Then, I'd ship my camshaft (and bearing) to WebCam, asking them to hard-weld and regrind (grind # 40a), also request them to re-press the bearing on the reground camshaft. This process costs less than an OEM camshaft; plus, you get a really great cam.
Tree Farmer
Old Jul 25, 2000 | 11:49 AM
snakeyes93's Avatar
hi,
thanks alot for the very useful info. without u i would be in the dark. i got a couple more questions, how tight should the cam chain be? also do u think i could do this with the engine head connected to the block with it all on the four wheeler? and would i need to take out the valves or anything in there? also what is the price for a cam shaft and the price on regrinding it ? and one last question, could u give me the web site, address or phone number of web cam? sorry for these questions, but thanks alot for the help and advice
john
Old Jul 25, 2000 | 08:29 PM
The cam tension is set by the cam chain tensioner, a component you must remove to perform the operation. It's the cylindrical-like thingy held to the rear of the jug with two bolts; has a tension bolt on the tensioner shaft collar.
also do u
You can do the entire thing with everything hooked up; might not even have to remove the tank and plastic.
>there?
Nope. Not if you line up the cam chain sprocket index marks at TDC, as I mentioned.
Ask your dealer about the new camshaft; Webcam charges around $ 100, I think.
>number of web cam?
I can't locate their phone number; try Information; they're located in Californis (Web Cam, Incorporated). They had a website, www.webcaminc.com , but I've been unable to contact them there recently. Good luck!
By the way, if you want to look at an exploded parts diagram, go to the parts catalog on www.buykawasaki.com You have to register and all that, but then you can enter your year and model and view exploded parts diagrams of everything.
>and advice
>john
You're welcome!
"Tree Farmer"
Old Jul 28, 2000 | 11:15 AM
doug_blackburn's Avatar
Classic Tree Farmer- constantly prowling the forum, always ready & willing to lend positive, intelligent, gramatically-correct assistance to those in need. Good man, Jim.
Old Jul 28, 2000 | 02:08 PM
Thanks for the kind words, Doug! However, my act plays to decidedly mixed reviews, as you know (helping me maintain my humility, certainly).
I hope my posts are also correct in ways besides the grammatical.
Tree Rarmer
wendal
Oct 31, 2017 03:31 AM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
rcappie4
Sep 9, 2015 07:04 PM
