warrior compression????
Old Apr 25, 2004 | 09:20 PM
YAMAHARIDER4LIFE015's Avatar
Default warrior compression????
Hi
can someone tell me how much compression a 98 warrior should have. I am only getting about 105 lbs
thanks
Old Apr 25, 2004 | 09:27 PM
ZBlaster's Avatar
i believe as long as it has over 100 its alright... dont quote me on that but i believe thats it...
Old Apr 25, 2004 | 09:30 PM
thanks for quick response
Old Apr 25, 2004 | 09:31 PM
ZBlaster's Avatar
no problem man... i try to help when i can...
Old Apr 25, 2004 | 09:37 PM
yamahawarriormods's Avatar
standard conpression is 121 psi..... minumum my manual said is 114psi and maximum is 128psi
you might want to check your valve clearence
Old Apr 25, 2004 | 09:40 PM
ZBlaster's Avatar
hhmm i was wrong... seems u learn something new everyday... check ur valves and if its all alright its probably time for a rebuild...
Old Apr 25, 2004 | 09:48 PM
thanks, I just adjusted the valves, the intake had been too tight, I am hopine it didn't get burned or mushroomed.
Old Apr 25, 2004 | 10:20 PM
good luck
Old Apr 25, 2004 | 10:23 PM
Raptorboy4life's Avatar
good luck too man are you going to bore that thing?
Old Apr 25, 2004 | 11:16 PM
yaaaaaa's Avatar
Go ahead and bore the thing. I just rebuilt mine with a standerd sized wiesco and it helped but wat the heck go ahead and spend 40 more dollars and bore it out some.
