this can't be right
My buddies keep telling me to get a 88 trx250r lenght swingarm which is shorter than the 86 trx250r swingarm.The prob is my front end is off the ground to much as it is.With a shorter swingarm wouldn't this only make it worse?They want me to get a aren's swingarm for a 88 but with the 86 style front part where it hooks to the motor and frame braket.
86 trx250r wiseco .020 piston,boyesen reeds,FMF gold series fatty pipe,power core 2 silencer,porting by p.m.s,motion pro twist throttle,motion pro clutch cable,PEP easy pull clutch perch and lever,white bro's white power shocks with adjustable res's all the way around,JD performance +2 A-arms,durablue eliminator 2+2 adjustable axle,durablue posi loc axle nut,nac's casesaver,uni filter,fastline braided steel front brake lines,braking brake pads,20/11/9 6 ply razr's on ITP .190 wheels,18/11/8 holeshot mx's on mitchell .190 wheels,21/7/10 holeshots on ITP wide off-set .190 wheels.www.angelfire.com/me3/fmf86trx250r
With a shortor swingarm, the front end will definately be in the air even more! What a shorter swingarm does is transfer more rider and machine weight to the rear of the ATV (resulting in more "hook-up"). Catch 'ya later!
My 86 has a much heavier front end than the 400EX, it is definitely harder for me to lift my front over logs and holes, so its a good mod for woods riding, but I like the heavier front end because with the wheel spin and lack of torque on a 250R I don't want my front end any lighter for climbing, which I do a lot of, so it depends whats more important, but I have never tried the 88R so I don't know how much difference it makes.
I would imagine a good welding shop could shorten yours that 1" (might have been 1/2"?) for a lot less than buying one, but the 88-89 is also a lighter swingarm.
Rod 86 250R
Rod 86 250R
