polishing aluminum
Old Apr 26, 2004 | 05:29 PM
Vinson581's Avatar
Default polishing aluminum
is there any way to polish brushed aluminum? like a dull pipe, or such?
Old Apr 26, 2004 | 06:20 PM
800screws's Avatar
it's easy! if u have a bench grinder, just get the pad and some compound, sears carries it. that's it. buff your way to a shine
Old Apr 26, 2004 | 07:30 PM
Vinson581's Avatar
what do you mean by a bench grinder? like a big belt or disc sander, that you can put a type of pad on?
Old Apr 26, 2004 | 07:39 PM
KGB's Avatar
KGB
No, a bench grinder. They have the grinding wheels, but you can change them to buffing wheels. You can also buy a pad to put on your angle grinder. If its got very deep machining lines, you will wnat to sand it with a fine grit paper, other wise it takes forever.
I always polish my pipes, they look alot better.
Old Apr 26, 2004 | 07:59 PM
Vinson581's Avatar
is there anyway possible to do it by hand, and buff it with the angle grinder?
Old Apr 26, 2004 | 08:20 PM
SANDMAN430's Avatar
harbor frieght sells them for 59-70 bucks and yes they make liquid polish, but it would take longer.
Old Apr 26, 2004 | 08:37 PM
MBrooks420's Avatar
How much do you want it to shine? You can get buffing pads for larger angle grinders. I'd use a fine(soft) wire brush cup on a drill.
Old Apr 26, 2004 | 09:01 PM
aksafari's Avatar
crocus cloth can be bought in long strips, it's SUPER fine and would be good for taking moderate 'brush' lines out of aluminum, then follow up with a cloth and compound polish.
unless you DO have a 4" angle grinder, then you could probably get the same job done in 1/10th the time and effort. BUT, a polished surface will lead you to very **** behaviors... I stripped my paintball gun barrel of black anodize, then super-polished it and had it clear anodized. I was CONSTANTLY shining it with my shirt, disassembling and washing, etc... It drove me nuts to see marks or fingerprints on it. Un-anodized, polished aluminum is a very fragile surface, you'll see little blems and grease marks really easily.
Old Apr 26, 2004 | 09:26 PM
Vinson581's Avatar
thats ok i want to do it with my pipe, no **** lube involved lol. where can i get this crocus cloth? and how much of a mirror shine will it give, can i put a buffing wheel on my ari grinder?
Old Apr 26, 2004 | 09:30 PM
Vinson581's Avatar
can i do the pipe on my rm, and get that mirror shine, you can see the pipe in my pics page.
