Fox Shocks
Old Apr 27, 2004 | 01:18 AM
04LERaptor's Avatar
Default Fox Shocks
What you know about these shocks? Anybody using them?
Fox Float AirShox
Old Apr 27, 2004 | 10:15 AM
sixsixT's Avatar
Default Fox Shocks
I'd like to try a set. The only thing is I see no way to adjust the hight.
Old Apr 27, 2004 | 10:18 AM
Shav0's Avatar
Default Fox Shocks
it says adjustable in the description
Old Apr 27, 2004 | 12:13 PM
04LERaptor's Avatar
Default Fox Shocks
Says that it comes with a pump to change the settings out on the trail...but I wonder if you can adjust the height.(Or if the pump will adjust the height)
Old Apr 27, 2004 | 03:47 PM
TheRaptorMan's Avatar
Default Fox Shocks
Has anyone seen a price tag on these yet?
Old Apr 27, 2004 | 04:11 PM
tryintoohard's Avatar
Default Fox Shocks
there is a guy selling them on e-bay for around seven hundred.
Old Apr 27, 2004 | 04:20 PM
yfzblaster1's Avatar
Default Fox Shocks
I wonder if they are acceptable for MX???? or if those are just for train setups..... might be interesting.....
Old Apr 27, 2004 | 05:43 PM
DaBeechMan's Avatar
Default Fox Shocks
ive ran a simular shock. They are designed for MX in mind. Expect to pay 5-700 a peice depending on who builds them.
Old Apr 27, 2004 | 06:26 PM
hondaracer305's Avatar
Default Fox Shocks
I wouldnt mind trying a set if my wallet let me [img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 27, 2004 | 06:41 PM
RaptorRacer1's Avatar
Default Fox Shocks
The coolest thing about these shocks, besides being really lightweight, is that the spring rate is fully adjustable by the consumer. For FREE! That means, that for those of you who love to tweek with things and play around with different setups, you can do it almost instantly with the hand pump. You just adjust the amount of air in the air spring. No need to pull the shock, take off the springs, order a new set of springs, put them on, re-mount the shocks.
This means, I would assume, that if you add wheel spacers, get wider a-arms, or anything like that, you can adjust the shocks yourself instead of having to get them rebuilt by a shop. At least that is how I understand it. If I am wrong, someone please set me straight. Thanks!
RR1
