olant dramas on banshee
Old Apr 27, 2004 | 08:57 AM
pommydude's Avatar
Default olant dramas on banshee
we are having probs with the coolant on the shee every time we go out and ride the coolant level in the back reservoir drops to about 5 mm ,the bike runs great apart from that ,the guy at the bike shop said we mightv be losing it through the piston and might have to skim the head wat do u guys think............
Old Apr 27, 2004 | 09:50 AM
Hiram's Avatar
This is how to check to see if the head is losing presure and causing the coolant to overflow, remove the radiator fill cap then start the bike and look inside at the coolant for air bubbles or alot of turbulance as when working properly the coolant should almost look motionless. Are you using a 50/50 mix of coolant and distilled water?
Old Apr 27, 2004 | 09:55 AM
Shav0's Avatar
skim it, it'll fix you prob and you'll gain compression. . .
jus't don't take off too much unless you want to run higer octane
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
