which fluids confused
Old Apr 27, 2004 | 07:11 PM
hawleywood400's Avatar
Default changing fluids confused
I am going to change all the fluids in my 2002 scrambler 400 4x4 what should and how much The one size fits all manual kinda S***s
Thanks
Tranmission
counter balance
front gearcase
hub
Old Apr 27, 2004 | 07:29 PM
Bradracer18's Avatar
Default which fluids confused
I used to use some kind of special oil in the counter balance and gearbox(I think it was belray) but anways, you need to fill the counterbalance until it runs out of the hole in the front of the motor, near the exhaust. And for the tranny, I fill it until I can stick a screwdriver in it and I have about an inch on the end of the screwdriver, plus you should have a dipstick.
Old Apr 27, 2004 | 07:31 PM
BigBadScrambler's Avatar
Transmission- 27oz of Polaris gearcase lube or Amsoil Series 2000 Chaincase lube
Counter Balance- 100ml (about 3.4 oz) of 10W-30
Front gearcase- 80W-90 GL5 gear oil. Good to use a synthetic or marine grade
Hubs- 2.5 oz (each) (fill at 4:00 position and let excess drain) of Polaris hub fluid, or ATF Type F or even better, use Mobil 1 Synthetic ATF (works great and the bottle will last a long time)
Old Apr 27, 2004 | 07:33 PM
thanks for the info that was pretty quick but on the transmission any other suggestions besides amsoil or the Polaris
Old Apr 27, 2004 | 07:46 PM
Prety much the only two you have to chose from for the trans. Not any other substitutes that I am aware of
akguy31
Aug 31, 2019 04:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Pissed off
Sep 21, 2015 02:33 PM
Halffast17
Sep 11, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
