35mm FCR Issues
Old Apr 28, 2004 | 01:57 PM
Yamaha660R's Avatar
Default 35mm FCR Issues
What would need tinkering to stop my FCR's from pouring gas from the overflow? I'm not sure if they leak on flat ground much, but on any type of hill they pour gas. Would the floats need adjusted? I hate to mess with them because this thing is running so strong right now. I can lug on hills, and do just about anything I want without a stumble or hesitation.
Old Apr 28, 2004 | 03:08 PM
XxDumontRaptorxX's Avatar
I donno congrats on 2000 posts though.
bump!
Old Apr 28, 2004 | 03:10 PM
Yamaha660R's Avatar
I've been out looking at the carb's, and I think some is loose and it's just pouring gas all over the place. I'm going to have to take them off and check everything, cause gas has been literally dumping all over the back of the motor and swingarm.
Old Apr 28, 2004 | 03:47 PM
RaptorOwner's Avatar
I would say take it apart and look at the float needle, maybe it has a piece of dirt in it or your floats have fuel inside of them maybe the floats need adjusting.
I had the same problem with my stockers at one time.
Old Apr 28, 2004 | 05:14 PM
FarmStud's Avatar
Might have something to do with the floats. You got it hooked up right don't you? I mean is it possible you the fuel hose hooked up to the overflow outlet?
Old Apr 28, 2004 | 05:57 PM
SpArX's Avatar
I would just keep adjusting the float level down to the point where it stops unless it starts affecting the performance of your machine from WOT operation and what not. It's a pain, but that's the only real way bout, do it in small steps, don't overshoot the adjustment and cause more problems than they'd be worth.
Old Apr 28, 2004 | 10:43 PM
Yamaha660R's Avatar
I'm going to check everything on the bike and see if anything is loose. It seem's like it's losing a lot of fuel. I'm going to take the pipe off and get a better look. Then elevate the nose of the bike and see where the gas is coming from. I started it today, but didn't since I rotated the tires, and washed and shined it. Tomorrow I guess I'll change the oil/filter and see if I can figure out the carb problem.
Old Apr 28, 2004 | 11:08 PM
04LERaptor's Avatar
Hey dude...don't let that gas overflow thing go without fixing it. Gas doesn't play and will burn your prized quad to the ground.
Just like this: Raptor Death
I know you just dropped some dough in your quad. Get it fixed before riding it anymore.
Old Apr 29, 2004 | 01:14 AM
Froooo's Avatar
Does the Raptor use FCR carbs?? I thought those were the carbs on the YFZ, CRF dirtbike, YZ450/250F & KTM 4-strokes. I re-jetted my friends Raptor carbs & they looked nothing like my YZ 450F carb.
Old Apr 29, 2004 | 01:41 AM
FarmStud's Avatar
No, FCR's are not stock, raptor uses mikuni's stock.
