how often is chain tighting on a scrambler needed?
Old Apr 28, 2004 | 10:57 PM
user3657's Avatar
Default how often is chain tighting on a scrambler needed?
it seems like i am readjustint the chain every other ride if im lucky........what gives? am i doing something wroung or is this expected?
thanks
Old Apr 28, 2004 | 10:59 PM
scrambler123's Avatar
I have to tighten mine every 2 hours of riding or so but it may be because I dont have the chain guide on.
Old Apr 28, 2004 | 11:17 PM
quadracer18's Avatar
Just want you to know that your not the only one out there!! I have to tighten my chain on the scrammy about every third ride I do..they do seem to come loose pretty easy..specially if you hit jumps with yours...so its not uncommon.
Old Apr 28, 2004 | 11:37 PM
jmrpage's Avatar
well the first thing i can tell you is to take off the factory chain and find a nice place for it in the garbage can . buy a new front and rear sprocket and a good chain like the did x ring that i bought for mine . i lube the chain after every ride and i adjusted the chain when i put it on and once after the first month of riding and have not had to touch it since . the chain is now a year old no problems and i do not run a chain tensioner , chain guide , or the factory ring around the rear sprocket . my only regret is that i didnt do it sooner .
Old Apr 29, 2004 | 12:24 AM
user3657's Avatar
well everything is stock so whatever came with it is on there......chain guide whatever.
how would a new chain fix the problem? i dont see how..............
Old Apr 29, 2004 | 12:54 AM
BigBadScrambler's Avatar
Do you jump much? If you do, invest in a chain tensionor. You wont have to adjust it nearly as often
Old Apr 29, 2004 | 03:30 AM
maybe thats part of my problem i jump some with no guide or tensioner.
Old Apr 29, 2004 | 06:54 PM
user3657's Avatar
nope i dont jump at all.........
Old Apr 29, 2004 | 09:42 PM
fishslab's Avatar
The stock chain is crap. It will stretch and wear a lot. I adjusted every ride until I got a tensioner. Then it was every three or so rides. I put DID xring chain on adjusted it once after a good long ride and have not had to mess with it again. I'm sure it will require attention again some day, but not everyday!
Old Apr 30, 2004 | 04:06 AM
71stang99's Avatar
i noticed mine is way loose after two rides, what is the chain lenght if you order an aftermarket one, sprockets are only needed if they are old right? if you adjust the factory one you do so with weight on the quad? instruction manual is iffy at best.
thanks
