ITP....
Old Apr 30, 2004 | 03:08 PM
espi21's Avatar
Default ITP....
Hey guys, I have just mounted my new ITP's on my polaris sport 400 and I cannot get the lugs to stay tight. After I do some hard running they seem to come loose, any advice would help....... Thanks........[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 30, 2004 | 03:51 PM
Bradracer18's Avatar
Default ITP....
Are you tightening them down tightly?? uhhh....are you putting the nuts on in the right direction?? I don't know about this, but I suppose you could try some mild loctite...
Old Apr 30, 2004 | 07:47 PM
maddog56's Avatar
Default ITP....
If you are using c series wheels you should be using the lugnuts that are made by itp. They wheels are aluminum and tapered in the holes and the lugnuts should be too. Most stockers arent.
Old Apr 30, 2004 | 10:07 PM
dunerdogg's Avatar
Default ITP....
I have the same problem on my skat trak haulers .... I tighten my nuts down tight and then i get back from a ride and the pretty just a little more than finger tight ...... im stumped
Old Apr 30, 2004 | 10:27 PM
fishslab's Avatar
Default ITP....
Did you guys turn the lug nuts around so that the flat side is against the wheel?
Old Apr 30, 2004 | 11:22 PM
MudTroop's Avatar
Default ITP....
I had the same problem, lugs backed all the way off on a ride. Wheel came loose luckily it stayed on just long enough for me to get shut down [img]i/expressions/face-icon-small-shocked.gif[/img] . I told my dealer, who is a friend and he said some of the sportsmans may have too short of studs for the new ITP rims. This is due to ITP making the rim thicker for durability. He told me to bring in my bike and ITP would pay for the new longer studs. You guys may want to ask about this at your local dealers. Hope this helps.
Old May 1, 2004 | 02:09 AM
dunerdogg's Avatar
Default ITP....
And yes fishlab I put my lug nuts on so there flat against the wheel .... and it doesnt seem to happen when i stick my shreders on there so its gotta be the wheels .. and when i stick those shreders on i put the lugz on the oposite way and they dont come loose ........ its gotta be the rims
Old May 1, 2004 | 12:44 PM
fishslab's Avatar
Default ITP....
The only other things I can think of then is to use a lock washer or some thread locker. Has it ruined your rims by wallering out the holes yet?
Old May 4, 2004 | 08:43 AM
pete/ny's Avatar
Default ITP....
All you guys running the C series wheels on your Sportsmans, you need to install the longer lugs.Big Buck Atv sells them and they will prevent the lugs from coming loose and possibly causing a serious accident.ITP will NOT pay for longer studs-been there-done that!!!
